Nissan did a 4WD pulsar that wasnt turbo.... looked like this though
nissan-pulsar-srv-1997-151108_1aa89.jpg?
so could buy 1993 GTiR... or 1997 SR-V... or just get an AWD turbo bluebird.
dat Nissan space-wagon logic.
maybe nissan wanted you to buy one of these:
:hurl:
Pretty sure it's been done before, and there'd be certain perks in doing so.
But also consider that it's most likely cheaper and easier to sell it and buy a GTT after your four years is up.
Moreover, consider the fact you may not want a skylineand post-Ps. My mate has a 34 GTFOUR, and I'm pretty sure for a long while he was considering N.A.+T. Has the AWD as well, so.
It's actually for sale at the moment as he's just got off his p's, if you want I can find deets for you (you could ask him deets about the brakes etc at least, I forget how much he's wanting for it).
But, I digress. He's on the hunt for an STi now. Which was my point about four years being a long time ; and that things change.
+ 1
I wouldnt waste money modding an NA
Would be easier and less headaches to sell it after your off your P's and buy another car
:hurl:
family is getting bigger. would own.
the farkin thing would tip over trying to enter the bolte bridge at 60km/h. Probably doesnt clear the height limits at most shopping centres and airport carpark.
it's not a sports car
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
