Got pre-approved for finance. Only one company would finance a car that old, but wouldn't finance a Skyline. -.- Too much hoon for them, probably. So now the chcices are: Different car (may have to be newer, dunno) or Personal loan. I'm oging to talk to the mortgage choice guy and find out about personal loans, though I am defs considering a Maxima Ti after driving Mike's. Was nice.
Yeah, he already suggested that when I got into his for a quick spin.
There's so much choice out there and I think I'd be happy with any almost any car from the late 90's onwards. I just want a skyline so badly and don't want to have to wait. :( Stupid Laws
Can anyone recommend where I should be looking to get a fibreglass repair kit to fix up two front bars? Both require multi cracks etc patched over a 10+ cm area... So one of the little kits from Super cheap ain't gonna cut it...
Try Paintmobile on Cheltenham rd Dandenong. They should have everything you need.
leeham will tell you to get a sss.
this.
SSS will munch NA 31,32,33 & 34 all day.
SSS with decent exhaust, some interior removed and good tread will keep up with turbo 31,32,33 & 34 most of the day.
inb4 hate.
  • Like 1
this I believe
this i am dubious about
Lol trying to quote your post accidentally clicked on your name and went to your profile bucket boy, says you're 22...
So ideally you shouldn't be on Ps any more / shouldn't have long left?
Just go forced induction from the get go then?
What is this the f**kin YouTube thread?
Anyway, three way rolling between SS ute, Evo X and old faithful.
SS gives the thumbs up after losing; this is common for Commodore/Falcon drivers to do, I've noticed...and I love it because it's just mutual admiration for another car being quicker, it's respect (to some people, that's more important). Evo on the other hand, looks dead ahead like he's thinking "why isn't my car faster? I spent 50k on this shit." Remind me again why we pole fun at the taxis when the import owners are the sore dream boats?!
/stillhaventgrownup
if I rock up next to a sports car with their window down I usually put it in 4th, give it a little bit for a second for dat supercharge whine usually scares most off :P
I had some xr6t ute playing with me down the monash yesterday, thing was pretty darn quick sleeper as with those chrome plumber pole things just looked like a work ute, apart from the xenons he had on it.
getting bored of 370rwkw doe might have to go for 450 or 500 soon
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
