I've had a leather flip wallet from yd. for years now, still going strong.
Tending to use a money clip these days though, with all the money I'm making. #ETU
thats cute #mininglyf :P
jokes, i aint back by union so getting paid cents :(
2 eps into top gear, starting to get real sick of the British government and military propaganda
+ huge bias towards UK cars. That's probably my main annoyance with the show.
its f**king british.
dont like it? dont f**king watch.
Well it does make sense, BBC is heavily controlled by the UK Government, so there is def some political motives to promote UK brands and keep local production alive...
Top Gear Australia: Votes Toyota Camry #1 Car in Australia
wut?
bbc is completely owned and funded by the british public....
lol at propoganda....
top gear hates the government, its well known in the uk, and have actually had politicians on the show and made them look like fools.
they love the military. which is a bloody great thing as no f**ker else does. but entitled civilians such as you lot would not understand.
thats my rant over for today. god i need a smoke. 3 days im starting to get angry at stupid things.
I want a nice small wallet that only fits cards and notes. Don't carry coins anymore
you cant avoid coins though. topping up myki on the fly, paying for beers over the bar, parking ticket machines, milk bar etc.
I'm looking for a new wallet cause the zip that holds notes/coins in is stuffed. so sick of dropping coins everywhere. Have a spare wallet but nowhere to put coins or even notes securely.
