Yeah chasers put a bog stock one on theirs as well:
Late last week we had the pleasure of putting a 2013 R35 GTR black edition on the dyno. We were a little bit surprised to see it put 326awkw down stock, and 332awkw with a full titanium powerhouse amuse exhaust.
Came home to two letters from Vicroads :(
Looks like March is not going to be a fun month... or then again, maybe not, bike should be different by next year, unless next one also has March rego...
Birds drive me to Show & Shine so I can rock up in a clean car.
hoping they only regos?
i got 2 this month as well
Yep, both the bike and the lancer. Haven't paid rego on either one yet since I bought both with relatively long rego left on them; but now through some stroke of fate, they are both expiring within like 5 days of each other or something ;__;
Needs more final inspection
Not that I doubt Damien's abilities, but unless he can add a 4th dimension to the universe, I can't see the reflection being any deeper/better than a pure mirror :P
Artz and Birdz detailing ftw
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
