I'll line up, and charge Alex a premium before race wars
edit: $150 a hour? sure
nah but srs yeah 150 seems fair for whoever needs money, similar to dat dere flaggy money @ sandown
Edited by UNR33L
So carrying on from a couple pages back, does ID make 1000cc side feed or would I need a GT-T or GT-R rail? And also will my R33 GT-R fuel pump support e85 and flow enough for ~270rwkw? What else do i need? Fuel filter obviously, will the lines be okay? e85 n00b here ;)
You will need to change to a top feed rail. A Walbro 400 or similar would probably be a worthwhile upgrade. Lines will be fine but really you're supposed to replace all rubber fuel lines every 5 years..
nah man i collect them its for my personal collection.
must acquire.
I know a guy with literally hundreds of pairs, is mad into all the new releases etc. Can put you onto him if you can't get a slave to line up for you
And I can't edit on the app
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
