I know a guy with literally hundreds of pairs, is mad into all the new releases etc. Can put you onto him if you can't get a slave to line up for you
And I can't edit on the app
Cheers man yeh got a few mates with massive collections but think I got it sorted
Cheers brah
thats not it brah thats a X
its these
lebron-11-gs-glow-in-the-dark-02-570x570
well whats fair for doing that? $150?
i tried not to comment... i really did... personal taste and all...
but seriously...
they look like they fell out of the dick tree and sucked off every branch on the way down
  • Like 2
l don't get the whole "i'd never wear these cos i'd look like right twat but cot daym I need to pay hundreds of dollars to have them in a box that I never open" thing
Well considering they are already going for double retail on resale market it's pretty easy to understand imo
