I would have bought it 3 years ago.
I was looking for a DC2 VTIR. But not very hard, as I preferred a BB6 VTIR, and checked a few of those instead.
My bro is 18 this year, maybe I'll ask him LOLL
Pics?
Come around for a Tax meeting and see for yourself
Young female that hasn't yet caught on what appropriate business attire is lol
Does she comes with it?
Doesn't that mean it needs a new gearbox?
When you come into the office to sign your Tax next week come have a peak and ask :P
  • Like 1
Will do! :D
drove past a small domestic car in the bolte just before. ran across 3 lanes and then tried to clear the cement wall for a 30m+ fall, but didn't make it. don't know how it got all the way to the middle of the bridge...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
