Care to share the story behind this?
Hills run through Reefton spur last night, wet roads, moss etc.. Lost it mid corner and spun into guard rail. Crash happened at or below speed limit, luckily the dude walked away not even a scratch.
Very lucky driver then
At or below speed limited and ended up over the Armco.. Sounds unlikely
You're driving through the hills, Speed Limit != Safe Speed, if you're on the limit of grip and something goes wrong it doesn't matter if you're doing 20 under the speed limit, you can't suddenly get more grip to recover...
So he was going too fast for his car / skill level if he rolled it over guard rail.
Any idea what is on the other side of the car? Did he managed to land the car right there and narrowly avoid a 50m drop? If so, awesome :D
Yeh, was most likely driver error, was more eluding to the fact that I don't think he was intentionally driving recklessly, just lost it and couldn't recover. 10ft embankment behind the rail, so nothing too exciting!
Saw this other day, been on gummers for a while.
I've set my eyes on a gtr up in Brisbane but having trouble getting time off work til after Easter :/
http://www.skylinesaustralia.com/forums/topic/439183-96-gtr33-v-spec-for-sale-original-condition/
lold hard.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
