I saw a little toyota starlet the other day at Trent's pushing 190kw, he was going in for an ethanol tune.
There is no way you would expect to get thrashed by a micro car, with a baby on board sticker on the window. I'm all for it. :)
this.
and because i can.
Pretty sure it was 4kg without tyre.
Haha yep. 2nd hand usually better.
When's sau winton day? Going tampered on 10th, I wanna beat my 53, especially when the 53 was my last lap of the day, and the car still had more in it. Gonna have even more in it now due to tyres.
17th May
That might be my first track day of the year. Not sure yet....
Lee dunno why yours weigh so much. Searching up 16x7+42, people saying the 16x7.5+42 weigh 11.1lbs, which is 5kg. Unless yours is 7.5? Dont think any te in that size should be 8kg.
i dunno mang, ive written down somewhere... ill go check my PGA thread.
It all comes down to turbo selection, and yours should be good for similar powerz...
yea ill have the bolts capable of doing it..... but its if the engine can take the hammer this time round....
maybe the next one will.
i know.....
im excited.
need to get it on the road asap.
scotty mate of mine needs his clutch changed on his s15..... he has the clutch already.... wanna pm me a price to fit it for him????
you do clutches right?
I can do anything you like for the right price Platts. ;)
No idea how long it would take though. Is he mechanically minded? I might need a hand... Could save him some coin too.
no i dont believe he is. if im free i will help though.
Thinking of getting a major service done on my n/a r33, anyone know who/where the best mechanic is to take it? Just want to take it to someone whos had experience with these cars before, unless you guys think taking it to a local mechanic will be fine?
Why aren't you sure? Scaredy? :P
Still need to shave the front suspension, fix heater hoses and oil cooler with Scotty Customs sometime :P
Then need to sort out suspension/alignment as Im sure I was hearing weird noises at Sandown. Steering wheel shakes a bit on the freeway. and for some reason the rear left sits a good 2-3cms closer to the body than the rear right :/
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
