Someone find me a torrent for the MC hammer movie
Too Legit: The MC Hammer story, I believe it's called
http://www.imdb.com/title/tt0283457/
Looks horrible, not even worth a synopsis or cover art apparently.
Anyone give me a reason why I shouldn't buy these:
http://www.ebay.com.au/itm/DeatschWerks-01J-00-0550-6-550cc-min-Fuel-Injectors-Set-of-6-/331074662353?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d15966fd1&_uhb=1
The're within the budget, should support ~280rwkw goal and Trent recommended them as being pretty good quality.
Because you can get near new R35 injectors and an rb26 fuel rail for less still.
Surely flow-matched and new is better than possibly mismatched and used? Or are the Nismo items that much better?
Much of a muchness for performance; they are probably all made in the same factory anyway, but Nismos have been proven time and time again and they hold their value well in case you part out down the track.
yaaaay housemates are gone. left plenty of stupidity behind though. filled the rubbish bin with balloons they didn't even deflate, and asking me if I'd seen an engagement ring they lost last week.
Find ring
Pawn it
Spend it on Meisters for the Pulsar
Profit
they just cleaned the house to get their bond back, they'd have a better chance of finding it than me. probably only went looking for it because immigration department needs proof of engagement.
lol. they stopped wrapping burgers to prevent the mangle ness and also ditched those cardboard bands so you can't tell when they've reduced the size of the burger (which they've done a few times in the last few years)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
