Anyone give me a reason why I shouldn't buy these:
http://www.ebay.com.au/itm/DeatschWerks-01J-00-0550-6-550cc-min-Fuel-Injectors-Set-of-6-/331074662353?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d15966fd1&_uhb=1
The're within the budget, should support ~280rwkw goal and Trent recommended them as being pretty good quality.
I'll be selling some 750s soon if ya looking....good as new
Actually my whole 300kw setup going up for sale soon so if anyone keen on anything hit me up ;)
so you are gonna part out Dave? damn. what you gonna do with the leftovers?
nah putting the stock turbo kit back in and probably swapping for JZ Cressida project...if he changes his mind i'm gunna spew but arrr well..Skylines not doing anything useful anymore
:D
sorry to hear. didnt think JZ would be your thing
jay-z.jpg?w=680
Celsior or cressida with 1UZ is where its at for toyotas. JZ's too pricey.
you know big engine toyotas Alvin, what you think?
Well to be fair its a decked out Cressida, it's in bits, and I'm swapping a perfectly good skyline for it...
Wasn't going to but I am loving this Cressida, so no nice to drive and so unassuming...I get more compliments in it than I ever did in the 33 ..
Speaking of burgers
Just got tagged in this
inb4 Martin/Hamish/Dess with an opinoin on list :P
I haven't eaten at any of those places
HS Top 10 Melbourne Burgers
http://www.heraldsun.com.au/news/victoria/melbournes-top-10-best-burgers/story-fnkd6ppg-1226836416557
dem v8 soarers, many slow, much noise, wow.
The 1UZ is a slow POS and, unless Scott puts a turbo in the boot for you lol
lol shows how much I know about toyotas.
celsior with exhaust sounds and looks good.
...want a nice burger for lunch now...
one of them tried to give me a run off the lights (i think?) dat passenger giggling doe
but yea aaron was f*kn slow as lol I'm talking n/a skyline slow :P
those new mercs are growing on me, the amg 45s or what ever they are, wonder what their economy is like.
Edited by UNR33L
jay-z.jpg?w=680
1uz sound sick, but so do worked 1jz
depends what the car is for though, I would never want the crown to be fast, sounds good now after the exhaust but that's all the performance you really do on a vip car
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
