yeah drags are pretty fun, trying to squeeze that extra .1sec out always a challenge and the adrenaline pumps hard when you're racing or about to launch
really cheap compared to track days, and no need for racing licenses which is a bonus
Cam licence is like $95
If you want to compare value for money
Drag day is say $60-$100 and you get say 6-8 11-14 sec runs
Track day is say $200-$220 and you get say 6-8 15 min sessions
:P
How would that work? Simons car takes longer to heat up but he also installed a 53mm koyorad and Nismo thermostat at the same time. NA 25's don't take half an hour to heat upand I'd imaine with the turbo engnes oiling system cooling the turbo as well it would take less time to heat up. We don't have consistently sub zero snowy winters here.
:P
drag day is 65 dowlar
but yeah I get what you're saying, less track time but still so fun
Doing the rounds on the internet today
https://www.facebook.com/photo.php?fbid=10151993276667358&set=a.389925412357.169612.197794592357&type=1&theater
Good to see the power of facebook in people able to identify the two sloots
Just come on the 22nd to volunteer. Be part of the action. And cheaper
Nah, busy that weekend already. Plus I'd want to drive, and car probably won't be ready.
Toby, Titman probs just bemad because he doesn't lift. (Inb4 secretly arnie)
:P
:P
Lol reminds me of fat chicks on FB bitching about "fit girls" being too skinny and should eat more
Edit: Not saying your Fat Titan, just saying theres a generalisation :P
Wasn't planning on it, but if you go down I'll come watch / maybe enter cos its cheap as chips anyway.
Will be throwing a twin 3" cat back exhaust on my car soon :D dat v8 burble brah
SAU had one at heathcote 2 years ago haven't had once since I think :( it was forum battle or something, won fastest ford trophy :D
Count me in if you and Toby are going down
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
