And JB website only has the 15" version, has 16gb RAM vs 8gb for the other 3 above, but also $400 more (and with a smaller screen)
http://www.jbhifi.com.au/computers/asus/n-series-15-inch-touch-notebook-sku-419058/
this ones got a touch screen which explains why it's a bit more $$
Edited by UNR33L
What I assume are the MR2 club are loading their cars into albert park for display
Naturally you must've guessed that because they're all prancing around with their boyfriends on their arm, not because you saw their motor vehicles. :P
And the hair care products
lol so true. dont really see the appeal of going to the F1s at all. would much rather pay a quarter of the price and actually watch some interesting racing with variety.
  • Like 1
I just sit back and watch Mohsens facebook posts about car dramas... it's butt-clenchingly exciting.
  • Like 1
Went for free last year, wasn't bad. Don't mind watching any motorsport as long as there's left and right corners
Nascar is probably the best spectator sport...and it was designed before every flamin mongrel had a TV and cameras everywhere...so back in the 50s It would of been great...but now more people watch motor racing on TV than at the track so its a different ballgame..
found a nice spot on the hill at PI the other day...and its completely different when you can see nearly the whole track, you see people passing and all the action and know whats going on without having to look at a screen or listen to a commentator...
So i can totally understand Nascar.....Its pedal to the metal non stop speed and action
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
