I was expecting to go out there and see him jump into some beast of a fpv v8, nek minute base model falcon... and someone at the end of the day called him out on it, "Left your XR8 at home did you mate?" and he looked embarrassed and took off the hat...
:( its ok to comment behind backs, but not to embarrass in front of. especially during a driver training... poor dude. hope you got your V8 buddy
I'm pretty sure the Mazda still becomes at fault, the Lambo would still get fined for excessive speed however the Mazda still turned onto a road where the Lambo was driving and needs to be the one to make sure nothing is there
ok so one of those hard decisions
midsummer's festival in Sweden ie party all night and not get dark.
or goodwood fest of speed.
note done the fest of speed b4.
katie is leaning towards goodwood
I'm leaning towards sweden
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
