Carrera is still the softer 911 though...
http://www.carpoint.com.au/all-cars/private/details.aspx?R=SSE-AD-2653649&Cr=7
But defs fanboys on 34R price front. :P. Or because none of the owners drive their cars they figure the lack of K's gotta keep price up right?
Perhaps later tonight Abz if you haven't found someone... Or Next week?
But I don't drink that beer shite. :P
Sweet! I can do whenever brah i'm about 60-70mm off the ground :/
Haha, corona pack? :P
If you're not a fan of mainstream beers, perhaps you could try one of these... :whistling:
http://mashable.com/2013/09/10/weird-beer-flavors/
This one could either be really good or really, really bad
