Woo free upgrade to business class. #mininglyf
Dat 20" screen and half bed
What you get that for?
Also, hope you're saving your points for the next Singapore visit...
thought V have full lie flat from perth,
those upgrades make flying good.
plus they offer to warm your nuts on emirates.
I'll probably eat beforehand anyway.
Also went to a different branch of gym than my own today, always makes me miss my usual. Also saw a guy in formal shoes working out. #dress2impress
Is anyone coming to Garage Cafe on Wednesday?
If Artz has my front bar fixed, yes. I've never been to garage cafe either. Only heard of it through here. Alvin, if you're a better cook, when's the next dinner at yours?
Just got platinum cred and they must have had some spare seats in business.
Points are saved. When is the next trip? :P
Get a schnitzel they always served me well there
It's a cafe in a warehouse what did you expect lol
do not take food advice from this man.
remember kids, he is going to die at 50 from colon cancer
fitted a Bee*R rev limiter to car last week (for ignition cut, not for flamage), was trying to crack the case because people havent had them working on FWD SR20's reliably. It works, but cuts revs very inconsistently...
Will do some reading up on fitting them to cars with EFI/distributor systems. Is that what the micra has? what motor is it? any other popular nissans?
They neglect to mention this treatment on the platinum cred section of the website lol
I should be a silver by the end of the year, by off my own status credits and hard earned money :P
If you keep going you can get plat for life I think? Like 7000+ status creds
Dunno when next trip but I wanna go back soon. Will have to tee something up with Jay for dat free accommodation so I don't have to bunk at a brothel in little India :P
  • Like 1
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
