I run ID's and if it's below 10 degrees my cars a bitch to start.
If the car has been on the trailer over night in winter and I try to start it at the track I have to wait for the temp to get up to about 10 before it will start.
It was tuned on a 35 degree day which probably didn't help.
Yeah on warm days, even anything above 15 degrees it starts first crank. Cold weather like today you can't even hear it fire a cylinder for the first couple of cranks.
  • Like 1
ive read a few articles mentioning the same amount.... maybe it could work.
id be taking it back to tuner and retuning in the cold tho....
Not a bad idea getting a winter touch up tune for it that I can switch to in the cold. Shouldn't cost too much.
yeah I didnt have any great issues either....Maybe its those crappy old Nismo injectors Birds ;)
I'd say it has more to do with the climate the car was tuned in and where you're starting it. My car gets left out on the street these days and inside the carport it does start much quicker. Pretty sure the bottom of my hill goes below sea level too, lol. Injector type or size should be pretty irrelevant; the timing and flow of them in the tune will matter more.
Besides, Nismo injectors are love...dat resale value through the roof. Just like my "outdated" PFC!
Need a tiny electric blanket around your fuel line birds.
Heh I was actually imagining doing something like this, but wrapping the whole engine. Also considered giving the fuel lines one of these
P.S. Medieval Lego ftmfw
Have a huge castle somewhere, so many trap doors and glow in the dark ghosts (actually just a regular Lego man in a ghost sleeve, but aren't they all!
  • Like 1
No, I prefer to get irrationally angry at people who get nostalgia about things that are 'silly new things that little kids are into'
Like Pokémon.
How dare this forum autocorrect and add that little thing above the E.
stupid nostalgic forum
well if your car is rwc...why worry?
sif be scared of tmu...just smile and nod politely as you do what they ask, then leave and do what the hell you want anyway
hmm only problem would be too low otherwise car is okay
always rely on much worse cars than yours to steal the spotlight. have seen bagged R32's scrape on modest carpark entrances infront of cops and they just watch to make sure no one does skids.
lol yeah this is true :P or i could just walk, market is pretty close. the melb car meets had a couple of people rev bashing and doing a skid on exit at the docklands one. :/
so you get told its too low...lift it...pass...then lower it again....
  • Like 1
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
