not to mention... a chef worth his salt will buy entire cuts and break them down himself which means he has a wide variety of choices to give you
take a ribeye for example.
so you clean up the whole thing and portion it. as the you go along the rib the steaks get progressively tougher and leaner.
so what happens is the shitty fat free tough as old boots ones get put in their own special pile for well done steaks and rude customer (or those that come in at close) then the chef has his little collections of the remainder with varying marbling, sinews etc.
you order the correct doneness and he will get one of the better ones.
you tell the waiter to "just let the chef cook it" they will go straight to the "piece de resistance"
Because ultimately, "rare" is subjective.
The guy doesn't know you, he only knows the 99% of other people that have come through and asked for "rare"
The only way you could ever really get it right, is if you go to a place and either
a) Luck out
b) go there enough times that you know what a baseline is for how they cook their meat
Same applies to "spicy" too
easy. bring me a steak. make it rare.
simple. could be f**king 4 inch thick or half inch. i want it rare. simple as fark.
every other flamin mongrel in the world at top restaurants can do it. why is it so hard in australia.
because a rare ribeye / scotch fillet for example is pure shit. it has fat that hasn't broken down and tastes like ass
a rare eye fillet is great on the other hand
a) Luck out
It's really not. See chart below
Sure there are in betweens, but you're not gonna whinge about a shade lighter or darker as long as it's closer to what you want.
should have been more specific there.
f**kING RARE.
I DONT GIVE A SHIT WHAT YOU THINK.
f**kING RARE.
chicken pork beef snail horse pigeon rabbit human.
rare. because thats what i asked for. and because your job is to cook food for me how i ask for it.
(i seem to have some hang ups about the quality of chef in this country hamish, this in way states i think your shite, im sure your a lovely chef, and that you trained at the fluer del loo de laeeuriruf french word and you meat is magnificent)
however of the 100 plus steaks ive eaten in this country about 2 have been cooked rare... and most have been shite. sure 90% of these restraunts where not "hipster class" but still give the people what they ask for man.
rant over.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
