the title of Apprentice Accountant will also be decided by steak cook-off.
PS. anyone know of a cheap car trailer hire? want to take to Winton. had a number from trailer I saw richo using once... dont know what happened to the number...
Vic Wastelands only has room for one accountant
There can be only one
And then a shit one from the future or space...
And then one that was better, but still had more than one
And then one where there was a shit load of them
Some meat is not good rare... Deal with it. It's fact.
Wanna try a kebab cooked rare? Didn't think so. Or perhaps a good ol stew or maybe even some good ol fried chicken
Hate to break it to you, but when it comes to cooking steak you don't know shit junior.
And I am actually qualified to say that :P
My dog likes rare chicken necks
So is every house wife for the past 1000 years. Grats.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
