anyone seen an OP6 rear GTT turbo on a 20 with a steel wheel (not highflowed as such) and 20 odd pounds rammed down it's throat?
wanna see how far I can go on a 20 without increasing lag
Stock R33 gtst turbo will get close to 200kw
I've got a hks2530 with 20psi. Gets around 230kw
seeing as a 33 turbo cant get 200 legitimately on a 2.5 I cant see it making it on a 2.0
hence why I was wondering about the OP6 rear w steel wheel and lots of booooost
uwotm8? Boss wouldn't print me out the higher run, just wanted me to suffer so I couldn't brag of 200 wattz out of a stocker.
  • Like 1
Need someone to go out and look at it.. mudgee is 4 hours from Sydney
5k, treat yourself with another 33.
Just force your kid to crawl into back* and according to insurers it's still worth more than you'll pay for it.
*applicable to coupes.
don't want a cop magnet... we have discussed this
and 4 dr is MUCH easier
Lately, I've seen cops ignoring me at rbt's, driving thru cop hot spots, slightly speeding. Dunno if it's just me or cops aren't targeting at all (at least in north and east).
*shurgs*
Parts are accessible and cheap as f**k...1jzs are cheap as f**k...I have a fresh painted shell here in deep red if you want to build one...beautiful color...come have a look , get those creative juices flowing...onky f**k around is putting a manual in it..and its 92 model so won't get club reg for a few years....you can get 89 ,90 models tho
There was an jz engineered cressy in Brighton a few weeks back...under 4k..was.mint as ...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
