i think a little too big :)
mines got a 9 turbo fitted i think it should be fine
its got a fair few other mods - cams, injectors, 2.3L kit :D
Take me for a spin then!
And chuck a t67 in then.
ME either...bht I only had one....i would of prefered a 4 door 33 and put all my gear in it....wouls of been neat but then Cressida came along and turned my world upside down...
Is it a good or bad thing?
Also looking at club reg so non reg car should drop the price a little
while i see your reasoning with something cresta....parts availability for Cressida is just silly..I went to wreckers and there was 5, 3 were Grande...I got an LSD diff for 55$ out it in car didnt even change oil....good as gold.. and just about any other part I needed was sitting right there for the picking....except for drivers indicator...there all broken.. :/
Im also not sure crestas came in manual either...so you still have to convert...even if they are could be hard to find one....I will keep my eyes peeled for ya anyway...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
