of course somewhere in the world, someone will have a headlight for sale, but given the confines of the medium in which she asked, until somebody states otherwise in this thread, mohsen is in fact, correct.
What confines? It's the interwebs lol. I don't think Leesh was intending to source one exclusively from a person who posts in this thread.
Don't allow Moh to have this victory
then why not post in wanted to buy section, instead of here, the specificity of the post dictates that mohsen is correct no matter how much we dont want him to be.
logic dictates he is a winner.
Moh will be victorious whether you like it or not. He is the Osama bin Laden of 9/11 as he is the terrorist to this argument
picturing moh sat in his fridge and oven filled cave in the mountains laughing maniacly.
then why not post in wanted to buy section, instead of here, the specificity of the post dictates that mohsen is correct now matter how much we dont want him to be.
http://www.skylinesaustralia.com/forums/topic/443523-33-passenger-side-headlight/
Logic? Gooby pls
Location of the question is irrelevant, butthurt though that may make you.
An emphatic 'no' is simply not correct. You conceded that. Framing the question in strange contexts of your own choosing is a red herring.
In summary, f**k Mohsen.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
