is checking fuel pressure the best way to test if a walborough pump is working properly? or just safer to replace the whole thing?
Also chatting to previous owner last night (who is cautious, but also talks some absolute shit) and raised concerns about E85 on old fuel lines and seal (I have seen a document warning cars pre-2004 to steer clear of any ethanol blend because it eat through certian rubbers over time). He also mentioned E85 water/fuel separation if left stagnant in the tank for long periods of time... comments?
Please E85 propaganda experts, you're my only hope.
Fuel pressure combined with flow rate...
You can have a pump which can build up to 45psi over 2 seconds, and then a bung pump which can build up to 45psi over 10 seconds due to low flow rate... Only one of these is going to be able to keep up under high boost situations, do SR20's have a rising rate FPR?
We even for last night lol. But know you owe me twenty for actuator. But I owe you for muffler.
Where does it end!
Huh?
Why do I owe you for the actuator again?
I work on car for free then? Oh okay.
Hey everybody free repairs farken.
Im joking. I got one jd
This is not enough to cover an angry ass pregnant wife that thinks I'm having an a fair with scotty.
LOL @ an affair.
In that case... A slab of ze german beer.
Most of those documents regarding ethanol and old fuel lines are propaganda written by companies with a vested interested in keeping motorists using normal petrols or distributors being overly safe for liability reasons...
And we may spout pro-E85 propaganda, and then it becomes he says she says...
But the difference is, that the pro-E85 people actually have thousands of running vehicles from the early 90s to prove it's not an issue. Now show me all those explosions and fires and clapped out fuel systems from using E85 on pre-2004 vehicles :rofl:
E85 for 6 months and counting!
St Johns First Aid training course tomorrow
Sitting in a classroom with a bunch of other idiots all day... meh, still better than work.
Just remembered I need to memorise a 47 page pdf of pre-reading info before I get there, blergh.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
