hey hamish
ive got a foglight button, but it does nothing
am i being a stupid head or are my foglights no worky or 8 doesnt have em?
ive also got the rear fog light button but it wont do anything as theres no rear fog light - but havent tried the switch
the ones with red stars turn on by either doing high beam, normal beam
hey hamish
top left - parker
bottom left - indicator
small round - low beam
big round - high beam
round on right - fog
So sounds like no fog for some reason
UK require a rear fog by law iirc?
yeah its odd
i just cant seem to get them to turn on
in the UK it needs to have the rear fog light installed and switchable (its on the rear bar) and it looks ugly as sin
thank god mines been removed, but the switch is still there
let me go play again
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
