Celicasupra is what that is, got a mate with one. He's taking his to DriftX in November, a pretty luxury car for the mid 80's imo.
nah this one a celica, the supra had some body changes like flared arches over this one.
Yeah just a Celica
I'm thinking of.. how many seasons are there? And when will the current one finish?
Its only like 10 episodes a season
We are on season 4 and that only has 2 more episodes to go
1/2 the time i cant remember which characters are which or whats going on but its good lol
I've been told is basically soft core porn lol no wonder you like it
You think it's soft core porn, then it turns into snuff porn... and the internet fans gets angry every week when their favourite pornstar gets killed, then the rest of the internet gets angry because they won't shut up about it.
Pretty much sums it up
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
