Just double checked to see Orlando wasn't in the list I posted.... I don't think I could have ever lived that one down
yay, my kids names are not on the list :)
Too hipster to appear on the hipster list...
Sweet as mate, bring the Cressy down
:thumbsup:
i wanted to call my second daughter Chilli for a while....good thing i was talked out of it, turns out Craig Lowndes kid is named Chilli...
I dont think I could of lived that one down...lol...its actually worse than calling your kid Brock
Going into it solo /foreveralone style also.
well theres ya problem.
but yeah +1 to too big of a financial commitment for me to bother.
interest, rates, stupid long mortgage + possible body corporate... fun times.
rather just use money to get by, have fun, then go live in a commune fearing barcodes and communists and await the inevitable rapture/2nd coming of son of rajab. etc etc.
then use super to buy a houseboat or something. whatever.
Pretty much... much harder solo unless you're on dat dere 6 figure + (inb4dezz) bachelor pad
Then my brain thinks of all the bad stuff that could happen.. get mrs, nek minit divorce and take half.. or nek minit made redundant at work, so could always rent but then money wasting away sorta. So far off the plan seems to be winner.
Edited by UNR33L
if you ain't no punk, holla we want prenup!
There's a woman at work who keeps saying she's from Mornington, but in reality she's more of a Frankstonite... Her kids are Crystale and Roxy
I'm honestly not sure how they didn't become strippers by word association
this is true.
reading through some drafts for a pre-nup recently... whats the point of an investment if someone can take it all off you? i'd rather just get some paperwork to keep it protected.
honestly I think any-one who is doing a pre-nup is expecting it to fail and prob shouldn't be married in the first place.
that said live with some-one for 6 months and they can take half anyhow. so too late for that prenup
When i learned that (maybe 12 months ago) i jumped on the wagon.
And also that if living with someone and theyre applying for welfare, the government expects you to support them. Which explains why its usually more than one person per household on welfare.
It doesnt guarantee anything, but i feel much better knowing there is a document stating that someone is a border and not a defacto or that certain shares/cars/investments are solely owned by someone or was owned previously to entering a relationship.
this is true.
I inquired about pre nups when I bought my place but was then advised that there is still ways around it.
Correcto, you can structure things and put agreements in place
But there is no 100% guarantee when it goes to Family Court
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
