richo when he had about 220ish RWKW did around 25-30 track days plus a years worth of driving on some AD08's so yeah they cost more...but they also last more.
If I remember right ash had some A048 or A050's on his GTR street driven when first got it, lasted about 5000km
So redoing my security clearance at work..
List all Overseas travel in past 10 years..
FML
hehhehe. i feel your pain. American government do not like the fact im british working for aussies on amercian tech.
if i was arab im pretty sure they would bomb the building.
FML
Will take you all of 5 minutes copying from your passports
In that time 45 people will contract HIV, 15 people will be the victim of violent crime in America alone and 500 people will die including
100 from starvation, predominantly children...
But yes... f**k your life... Princess
  • Like 1
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
