#@r34abz mate, as long as you don't have an inter-cooler with that pod, it's fine. As Alvin said, one intake mod is ok and if you've got everything stock you'll pass. EPA's are the reason I don't want to get an aftermarket exhaust.
  • Like 1
Check out this Mitsubishi Lancer.
http://www.carsales.com.au/private/details/Mitsubishi-Lancer-2001/SSE-AD-2839584
Nick is this yours?
Nope, mine sold on fleabay not long ago for $12k, un-regod, no rwc, recent engine swap, shit condition car overall and still had the jdm-007 plates
bit steep, are they forged? I got brand new TE37's for a little bit more than that...
I have no idea what my stud pattern is, what widths/offsets I'd need etc.. haven't looked into anything yet
pcd is 5x120 so same as bmw
however not sure on offset, would need to pull a front and rear to check if stamped on inside, if not need to measure and calculate
measure the exact width of th rim, from outer edge to outer edge (may have to lay it down and go with a tape from a flat surface from bottom to top as it's got tyres)
then measure from wheel hub to the lip on the rear
take the first measurement (lip to lip) and divide into 2
then take second measurement (hub to lip) and minus the first measurement from that
Meisters are rad. Sort it out Leroy Jenkins
LEROYYYY JENNNNKIIIIINNNNNNSSSSSSSSSSSSSSSSSSSSSSSS
Not forged, good luck finding good forged rims in these type of sizes for anywhere near this sort of money though ;)
Sure, if you ran pulsar sizes you could buy TE37s cheap.
:D
Green shell killshot just before the finish line is the finest play in the Mario kart book
there is a decidedly real satisfaction from sniping with green shells
but i was foreveralone playing with computer
Way too much effort. I'm sure it's on the internet..
Pretty sure it's just 2010+ models with power to weight of < 130 kW/t
Anything older will continue to be banned as per current rules / power to weight
I think you may be able to get a Golf R now. Saw some talk of this. Definitely the GTi I think?
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
