#@r34abz mate, as long as you don't have an inter-cooler with that pod, it's fine. As Alvin said, one intake mod is ok and if you've got everything stock you'll pass. EPA's are the reason I don't want to get an aftermarket exhaust.
  • Like 1
Check out this Mitsubishi Lancer.
http://www.carsales.com.au/private/details/Mitsubishi-Lancer-2001/SSE-AD-2839584
Nick is this yours?
Nope, mine sold on fleabay not long ago for $12k, un-regod, no rwc, recent engine swap, shit condition car overall and still had the jdm-007 plates
bit steep, are they forged? I got brand new TE37's for a little bit more than that...
I have no idea what my stud pattern is, what widths/offsets I'd need etc.. haven't looked into anything yet
pcd is 5x120 so same as bmw
however not sure on offset, would need to pull a front and rear to check if stamped on inside, if not need to measure and calculate
measure the exact width of th rim, from outer edge to outer edge (may have to lay it down and go with a tape from a flat surface from bottom to top as it's got tyres)
then measure from wheel hub to the lip on the rear
take the first measurement (lip to lip) and divide into 2
then take second measurement (hub to lip) and minus the first measurement from that
Meisters are rad. Sort it out Leroy Jenkins
LEROYYYY JENNNNKIIIIINNNNNNSSSSSSSSSSSSSSSSSSSSSSSS
Not forged, good luck finding good forged rims in these type of sizes for anywhere near this sort of money though ;)
Sure, if you ran pulsar sizes you could buy TE37s cheap.
:D
Green shell killshot just before the finish line is the finest play in the Mario kart book
there is a decidedly real satisfaction from sniping with green shells
but i was foreveralone playing with computer
Way too much effort. I'm sure it's on the internet..
Pretty sure it's just 2010+ models with power to weight of < 130 kW/t
Anything older will continue to be banned as per current rules / power to weight
I think you may be able to get a Golf R now. Saw some talk of this. Definitely the GTi I think?
