It will stop some crashing.
Go drive a 300kw skyline and tell me that won't increase your chances if losing it
You obviously haven't seen arab drifting on youtube.
You still can crash a 4 cyl Camry...
yeah any car can speed.
this was me in a 2L NA wagon all 105 Fly KW
training is more important that power to weight.
oh and earlier that day I had a 92kw FWD hatch at indicated 205!
yep, I remember getting a stock lancer rent a car over 200 with 5 people in the car...back mid 90s...
There will be ulterior motives behind this anyway...like raising more revenue from P-platers speeding..
you watch Kids all get excited about the new laws and start driving like morons...
then government will use this as an excuse to bring in mandatory GPS tracking or some bullshit....
They are just fishing, they're just giving a little slack before they reel us in further....
Not really,
I think it's just because soon pretty much all cars will have forced induction and there is NO WAY the government can look like they are forcing P Platers to drive older less safe cars
it HAD to happen
i always like the fact the holden cruze.
2 models the "sportier" faster was NA
the slower less powerful one a small turbo..
and which is the only one a new driver could have...
or you could drive the superseded Renault Clio Cup but not the less powerful mini cooper S
I could go on for days but yes how hard is it to find a small car released in past 2 years with no turbo varient,
It allows P platers to drive turbo diesels and weak turbocharged petrol vehicles.
However...P plater buys CA18DET S13...much easier to get big power out of these than even N/A V8, which I thought was the reason turbos got blanket banned in the first place except for those turbo diesels appearing on the unrestricted list.
Are V8s still banned?
So I purchased one of these which has an 85mm ID:
http://www.apexi-usa.com/store/catalogsearch/result/?q=500-a021
Not realising I need the 500-A022 model which has a 75mm ID. Anyone know how I can make it fit to the RB25DET? Would an adaptor or the like work?
Did you purchase the Power Intake adpator too? I don't think those come with one.
As listed here:
http://www.apexi-usa.com/store/induction/power-intake/universal-adapter-flanges.html
Oh and next time, save yourself the money and just buy a 3A racing pod off ebay for 30 bucks. They filter well and are cheap (as a piece of perforated cloth and some stamped metal should be).
Edited by colourclassic
  • Like 1
Love them or hate them, the VF commys are a respectable bit of kit. Electronic park brake is fkin cool.
13.8L/100km average on LPG, that's close to diesel economy when you convert to dollars, isn't it?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
