Yay! I've decided to supercharge the 6L and car is booked in for the 30th to get the charger fitted and tuned :woot:
Decided to go for one of these bad boys, mainly because it looks stock-ish:
http://4.bp.blogspot.com/-NS_WDLsBZq0/T1_LQpRAIiI/AAAAAAAAAqk/OsyXOdfz1uY/s1600/stealthforce.jpg
  • Like 1
lol nothing says Stealth like writing on the cover advertising that it is Stealth...
Hahahha I know, I'm hoping the "Stealth Force" and "Harrop" are removable. Not sure what I'm going to do with the "Supercharged" embossing on the side covers though :(
WIL B STELF M8!
Anywhoooo, planning on running E85 but I'm in Pakenham and even though there is a United quite literally 1km from my house, they don't have E85 :(
Might be a noob question but are regular plastic jerry cans E85 proof?
WIL B STELF M8!
I am sick of leaky jerry cans. If it doesnt leak when screwed on, it leaks when trying to fill anything. If i go E85 im going metal: 4WD style.
Yeah i use plastic jerry cans for my e85
Don't 100% trust it not leaking so it is slightly on an upright angle when in the boot
The yellow ones from bunnings are meant to be pretty good, cheap for their size and good seal at the cap.
Saaaweeet! I'll keep that in mind, cos otherwise I would be going to Supershit Auto and buying something there.
Re "stealth" charger
I'm guessing from that pic the part that says supercharged is removable?
Quick google says a lot of people were unhappy with the stealth kit until they got a smaller pulley
Yeah, the side covers that say "Supercharged" are removable but would really love to keep them on as they add to the "complete" look.
Shame it says supercharged, especially when it says "stealth" on the charger cover. WTF!
Is it about the dude with a VE HSV Senator? The guy is a goose, kept most of his exhaust standard and uses undersized extractors then complains when he can't get past 320rwkw. Apparently it was all in the tune cos he ended up reeling off over 500rwhp.
Also, I'm running a boost friendly cam and have a proper exhaust AND I shall be running the smaller pulley (aka boost upgrade) too ;) YYYYYEEEAAAHHHHHHHHHHHHHHH!!
So when we lining up :P
Also, any of you skyline peeps want to buy 114.3 19x9.5 +30 19x8.5 +17 varrstoens with NT05s? rears are pretty shagged doe.. :D
Hahaha when I know for sure that I'll beat you :P
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
