Aint even cheap.
First Kakimoto R cost me $80, HKS Super drager was $120 incl courier from qld, Fujitsubo Legalis Super Ti was $250
African American please. this is me. id offer him 50 bucks.
  • Like 1
Aint even cheap.
I should go to the exhaust place at the end of the street and ask him how much it'd cost for him to custom make me something with the same specs as the Fujitsubo Legalis Super Ti.
Surely it'd only be $250 since it'll have no big name branding or anything...
then ad 0 on end cos hes strayan.
:O
You dream about Skylines instead of Pulsar?
yeah... maybe cause i could thrash it and not care/break anything (important)
lucky skyline owners have aftermarket exhausts around every corner... most other people have to hunt 2nd hand stuff down or get custom.
go cry on a pulsar forum nancy boy
Also want to be taken for a spin :D
On another note, after going from shagged 275 NT05s to 245 Dunlops I've gone from traction in 2nd on good roads to 'lols' but I don't feel like I'm going to spin out to a tree in the wet which is nice.
Edited by UNR33L
Did you end up fixing your sexcel after breaking at Alvins? What turned out to be problem? May have asked before lol
yeah, clutch slave cylinder stuffed up along with gearbox.
It's running like a little rocket pocket now.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
