I got some Invicta watch when I was in the U.S, only really wear it when I go out or want to look professional, cbf most days at work been here long enough to not care
Toby I didn't realize (or think of it I guess) I could claim office chairs on tax #themoreyouknow
Edited by UNR33L
chrome and that kit :yucky:
plattsy, GTiR brakes are an expensive way of saying N15SSS brakes :P
AD22VF's also came on the NX coupe, so theyre around. write-up: http://www.pulsar.org.au/tech_ad22vf.php
cheers mate.
qdb1281 is the a1rm... sweeeeet.
cheers mate.
yeah theyre good pads. Jason gets them at a decent price.
been a fairly "mild" winter at Eildon so far, but today is proper chilly. reckon there will be some decent snow the next couple of days.
Im planning the family tobogganing day trip. anyone vouch for Lake Mountain or Mt Baw Baw? I've been to both but many moons ago and dont remember having to pay for entry up the mountain...
yea ill hit jase up when i get some kesh, hes getting my braided lines for me.
what brakes you running?
i got N15SSS rears and R32GTR fronts running A1RMS.
reminds me I need to bleed the lines.... but priority is to get the engine checked up. but that requires a day off. and a trailer.
gtr fronts?!?! wut!
so 33 gtst brakes.... you have to get you rotors drilled then i take it?!
shit the micra would do endo's with the 4 pot sumitomos.
its complicated...
older nissan small car hubs have some unique bracket size that only allow for swapping with other older nissan small cars.
N16 pulsar has a more common size, allowing FTO, maxima, skyline, silvia calipers etc. R32GTR sumitomo is the best for size/pad surface area/wheel availability for clearance. GTST are cast calipers and smaller pad but also 4 pot. brembo GTRs are bulkier and require spacers to fit im pretty sure. but if rolling in $$$ could get some aftermarket calipers.
N16 hubs machined and re-drilled to desired PCD, fit N16 bearings.
R32GTR calipers with N16 hub will take 288mm rotors, which means purchasing 300mm and machining down (not a fun job). then usually need rotors re-drilled too.
its complicated...
Gtst calipers are alloy, Silvia calipers are cast
Cast they are the same as Silvia calipers
This
you sure..... they all look alike to me.
plus literally everything on the wrx is alloy. EVERYTHING.
Definately, why they decided to go with the budget spec caliper I do not know.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
