my clutch is Helix Dual Plate Organic clutch so i think the clutch itself is ok and if you smash the gearchanges its fine
it only seems to happen when i granny shift (not double clutchin' like YA SUPPOSED TO)
You would think that
I would... and i'm right
yeah thanks, it kinda makes sense - ive got stock seats and std seat positon
i dont feel that the seating position is too high (at least, it seems OK)
but i swear, its as if i dont take my foot of the accel pedal enough (or properly) so its ever so slighty during gearchange, which makes it almost free-rev after clutch in/out
ill do a drive on saturday and log it and see what the logs show, it should show TPS not dropping to 0.30v if my thinking is correct on gearchange
very odd
is there a company who makes the brackets or did you do it yourself?
ay-ay-ron and I both bought them from the same place... some company in the USA... cant remember the name, I found it on the evolutionoz forums
I find one of the most annoying things is the car revs out slowly and drops revs equally slowly... it feels like the flywheel weighs 200kg
I didn't install the clutch, so i'm guessing tis' the stock flywheel
dont plan on building anything.....
just asking if hamish had heard of wierd clutch issues like i described
turns out yeah there might be some background to it, so maybe seat position is part of it
Seating position I lowered with brackets that bolt onto the stock rails. Now i see why you were saying you couldn't see the speedo, it's cos you have the stock seating position.
Stock seat height in evo's is TERRIBLE... It might as well be mounted on the roof for how high you are. Brackets will drop you close to 2"
Clutch wise, who knows... I have an HKS single plate so it's either on or off lol
I never had an issue with seat height...... dat short lyfe
Are evos designed for smaller statured folk like myself?
pretty much, well the jdm ones are anyway
adm have different seat bolsters to fit the bigger build
which one? he apparently made 3
his was the silver, there was a pink one roaming around echuca I think and a 3rd up north blue off the top of my head
From what I saw the pink vl from Echuca was only rwd rb30 but with a 26 head and twins on it, poss a different car, but that was about 10 years ago.
I remember hearing about the 4wd vl back when I was in school ( and that's a f**ken long time ago).
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
