my clutch is Helix Dual Plate Organic clutch so i think the clutch itself is ok and if you smash the gearchanges its fine
it only seems to happen when i granny shift (not double clutchin' like YA SUPPOSED TO)
You would think that
I would... and i'm right
yeah thanks, it kinda makes sense - ive got stock seats and std seat positon
i dont feel that the seating position is too high (at least, it seems OK)
but i swear, its as if i dont take my foot of the accel pedal enough (or properly) so its ever so slighty during gearchange, which makes it almost free-rev after clutch in/out
ill do a drive on saturday and log it and see what the logs show, it should show TPS not dropping to 0.30v if my thinking is correct on gearchange
very odd
is there a company who makes the brackets or did you do it yourself?
ay-ay-ron and I both bought them from the same place... some company in the USA... cant remember the name, I found it on the evolutionoz forums
I find one of the most annoying things is the car revs out slowly and drops revs equally slowly... it feels like the flywheel weighs 200kg
I didn't install the clutch, so i'm guessing tis' the stock flywheel
dont plan on building anything.....
just asking if hamish had heard of wierd clutch issues like i described
turns out yeah there might be some background to it, so maybe seat position is part of it
Seating position I lowered with brackets that bolt onto the stock rails. Now i see why you were saying you couldn't see the speedo, it's cos you have the stock seating position.
Stock seat height in evo's is TERRIBLE... It might as well be mounted on the roof for how high you are. Brackets will drop you close to 2"
Clutch wise, who knows... I have an HKS single plate so it's either on or off lol
I never had an issue with seat height...... dat short lyfe
Are evos designed for smaller statured folk like myself?
pretty much, well the jdm ones are anyway
adm have different seat bolsters to fit the bigger build
which one? he apparently made 3
his was the silver, there was a pink one roaming around echuca I think and a 3rd up north blue off the top of my head
From what I saw the pink vl from Echuca was only rwd rb30 but with a 26 head and twins on it, poss a different car, but that was about 10 years ago.
I remember hearing about the 4wd vl back when I was in school ( and that's a f**ken long time ago).
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
