Na they're good for some people, android are good for some people.
High end models android models are about the same price as entry model iphones, and are just as usable as iphones.
Specs aren't everything, so although iphone specs are a bit behind the 8ball due to their release cycle, the apps are designed for the specific specs... so the User Experience is the same. If you've got a low end android then you're going to have a bad time...
8 MegaPixel vs 16 MegaPixel.. who gives a crap... They both take great looking photos and handle low light really well. If you wanted a pro camera, you'd buy one, instead you're using a phone which is more than capable.
The Samsung S5 has a slightly sharper picture, the iPhone 5S has a slightly more accurate colour capture. Does anyone notice? No...
Personally, I'm an android guy, 100%... but the iPhone is still the best phone for some people, definately not for me though.
again. who?!
people who own iphones.
having swapped from an 5s to an s5, i wont be going back.
Reviewers for one. Most prefer the shots from the 5S. I use to work as a systems administrator and I currently do mobile app development, so I've worked with my fair share of phones from the different platforms.
Both iOS and Android are good platforms, I just can't stand the people who dismiss one or the other, it makes them look stupid and 99% of the time they have no idea what they are talking about.
This is true. The iPhone 5S processor is faster than the S5 though, even though on paper the specifications are lower.
Drip drip drip I wanna piss on youuu
sony z1/z2. waterproof yo.
Oh?
I know they're waterproof but are they beer-proof?
And do they take micro sim?
About rinsing, it could be a issue... Especially where I'm heading.
the f**k?!
just piss on it if you have too.
2013_0510_GetOutAlive_Bio_Bear-Grylls_90
Which cats got the tips / hookups for nurburgring drives, and also sports car rentals for ze autobahn
Looking at you Martin
Thanks for reminding me.
Martin the travel agent, show yourself please!
I used these guys:
http://www.rentracecar.com/?page_id=348
want to try their 86 next time in area
these guys also good.
http://www.rent4ring.de/en/
there another with a bunch of older alfa and such, avoid at all cost.
autoban I just hired a 3 series from avis did 220 no worries
Was looking at these sites just then, now to decide what car to use.
Should look around for lap tickets pricing. And decide what package should I go for.
Thanks Martin.
Also, whats the place where you go on a factory tour in Italy and you get to drive supercars or something?
Thanks Martin.
you mean these guys
http://www.motorstars.org/
if in the modena area as well I strongly recommend this new Museum
http://www.museocasaenzoferrari.it/en/
when I went there they had the history of F1 from early Maserati 250F through to senna's Maclaren and some newer one, all real cars dripping oil right in front of you
so not just a ferrari wank fest
Muchos Gracias Martin.
Gotta include Nurburgring, Oktoberfest, some of Italy, Greece, the sphincter of the universe and Russia, do wonder if I could fit Hungary and possibly someplace into the trip.
Off to do some planning.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
