Na they're good for some people, android are good for some people.
High end models android models are about the same price as entry model iphones, and are just as usable as iphones.
Specs aren't everything, so although iphone specs are a bit behind the 8ball due to their release cycle, the apps are designed for the specific specs... so the User Experience is the same. If you've got a low end android then you're going to have a bad time...
8 MegaPixel vs 16 MegaPixel.. who gives a crap... They both take great looking photos and handle low light really well. If you wanted a pro camera, you'd buy one, instead you're using a phone which is more than capable.
The Samsung S5 has a slightly sharper picture, the iPhone 5S has a slightly more accurate colour capture. Does anyone notice? No...
Personally, I'm an android guy, 100%... but the iPhone is still the best phone for some people, definately not for me though.
again. who?!
people who own iphones.
having swapped from an 5s to an s5, i wont be going back.
Reviewers for one. Most prefer the shots from the 5S. I use to work as a systems administrator and I currently do mobile app development, so I've worked with my fair share of phones from the different platforms.
Both iOS and Android are good platforms, I just can't stand the people who dismiss one or the other, it makes them look stupid and 99% of the time they have no idea what they are talking about.
This is true. The iPhone 5S processor is faster than the S5 though, even though on paper the specifications are lower.
Drip drip drip I wanna piss on youuu
sony z1/z2. waterproof yo.
Oh?
I know they're waterproof but are they beer-proof?
And do they take micro sim?
About rinsing, it could be a issue... Especially where I'm heading.
the f**k?!
just piss on it if you have too.
2013_0510_GetOutAlive_Bio_Bear-Grylls_90
Which cats got the tips / hookups for nurburgring drives, and also sports car rentals for ze autobahn
Looking at you Martin
Thanks for reminding me.
Martin the travel agent, show yourself please!
I used these guys:
http://www.rentracecar.com/?page_id=348
want to try their 86 next time in area
these guys also good.
http://www.rent4ring.de/en/
there another with a bunch of older alfa and such, avoid at all cost.
autoban I just hired a 3 series from avis did 220 no worries
Was looking at these sites just then, now to decide what car to use.
Should look around for lap tickets pricing. And decide what package should I go for.
Thanks Martin.
Also, whats the place where you go on a factory tour in Italy and you get to drive supercars or something?
Thanks Martin.
you mean these guys
http://www.motorstars.org/
if in the modena area as well I strongly recommend this new Museum
http://www.museocasaenzoferrari.it/en/
when I went there they had the history of F1 from early Maserati 250F through to senna's Maclaren and some newer one, all real cars dripping oil right in front of you
so not just a ferrari wank fest
Muchos Gracias Martin.
Gotta include Nurburgring, Oktoberfest, some of Italy, Greece, the sphincter of the universe and Russia, do wonder if I could fit Hungary and possibly someplace into the trip.
Off to do some planning.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
