Na they're good for some people, android are good for some people.
High end models android models are about the same price as entry model iphones, and are just as usable as iphones.
Specs aren't everything, so although iphone specs are a bit behind the 8ball due to their release cycle, the apps are designed for the specific specs... so the User Experience is the same. If you've got a low end android then you're going to have a bad time...
8 MegaPixel vs 16 MegaPixel.. who gives a crap... They both take great looking photos and handle low light really well. If you wanted a pro camera, you'd buy one, instead you're using a phone which is more than capable.
The Samsung S5 has a slightly sharper picture, the iPhone 5S has a slightly more accurate colour capture. Does anyone notice? No...
Personally, I'm an android guy, 100%... but the iPhone is still the best phone for some people, definately not for me though.
again. who?!
people who own iphones.
having swapped from an 5s to an s5, i wont be going back.
Reviewers for one. Most prefer the shots from the 5S. I use to work as a systems administrator and I currently do mobile app development, so I've worked with my fair share of phones from the different platforms.
Both iOS and Android are good platforms, I just can't stand the people who dismiss one or the other, it makes them look stupid and 99% of the time they have no idea what they are talking about.
This is true. The iPhone 5S processor is faster than the S5 though, even though on paper the specifications are lower.
Drip drip drip I wanna piss on youuu
sony z1/z2. waterproof yo.
Oh?
I know they're waterproof but are they beer-proof?
And do they take micro sim?
About rinsing, it could be a issue... Especially where I'm heading.
the f**k?!
just piss on it if you have too.
2013_0510_GetOutAlive_Bio_Bear-Grylls_90
Which cats got the tips / hookups for nurburgring drives, and also sports car rentals for ze autobahn
Looking at you Martin
Thanks for reminding me.
Martin the travel agent, show yourself please!
I used these guys:
http://www.rentracecar.com/?page_id=348
want to try their 86 next time in area
these guys also good.
http://www.rent4ring.de/en/
there another with a bunch of older alfa and such, avoid at all cost.
autoban I just hired a 3 series from avis did 220 no worries
Was looking at these sites just then, now to decide what car to use.
Should look around for lap tickets pricing. And decide what package should I go for.
Thanks Martin.
Also, whats the place where you go on a factory tour in Italy and you get to drive supercars or something?
Thanks Martin.
you mean these guys
http://www.motorstars.org/
if in the modena area as well I strongly recommend this new Museum
http://www.museocasaenzoferrari.it/en/
when I went there they had the history of F1 from early Maserati 250F through to senna's Maclaren and some newer one, all real cars dripping oil right in front of you
so not just a ferrari wank fest
Muchos Gracias Martin.
Gotta include Nurburgring, Oktoberfest, some of Italy, Greece, the sphincter of the universe and Russia, do wonder if I could fit Hungary and possibly someplace into the trip.
Off to do some planning.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
