dirt bikes are for bogans who like ruining forests and destroying silence for kms around.
i'd rather support hunters/shooters who actually enjoy the outdoors.
save your coin. for someone who lives at home, you sure do have a lot of space to put your toys.
That's rough man :( :(
I see your lengthy weapon and raise you pyjamas no self disrespecting hipster could ever cut through
2012-autumn-and-winter-new-men-and-women
I will cut around it so you bleed out slowly and painfully. you now have the added insult to your family of your corpse looking like a douchebag
I'm not saying they don't work but really they are not very much if at all cheaper than Garretts and due to having a plain bearing core you do lose some response(and that cool whirr down noise after the cars turned off :P) I just don't see them as excellent value for money.
Recon your $2500 500HP Garrett can beat one of mine $2500 500HP SS-Alpha in response? :rolleyes:
And Ball what bearing?
I choice to not to for good reasons.
you should always take into consideration the HELP/HECS repayment based upon your HRI dude
At least then you will know exactly what your tax position is
I can always dream can't i?!
Bro tip to self: buy more negatively geared properties
I'd blind you with a camera flash and given Apple doesn't support flash you'd be fresh out of luck
It's more of a joke to defend Flash these days :P Android doesn't support Flash either, it's a dead application.
Turbo looks good, but unfortunately its Chequered, so it's more like 350rwkw not 435 lolololol pls.
  • Like 1
You do realise that Trent uses a correction mode that gives basically the same results as a dyno dynamics... Only more accurate...
Just cos he does a better job than your mob for half the cash is no reason to hate :P
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
