Haven't been here for a while and then this happened at work today.
Grey R34 2doors came to our carpark at work just now, scouting for something don't know what it is and then they tried to go out from our car park and hit my colleague car and caused a damaged on rear bumper and body.
Funnily enough the front bumper of the R34 fell off with the number plate still intact from the impact and the bastards run away like a little cat.
Everything captured on CCTV and police informed so the bastard better watch out and see who's knocking on their door next.
I wonder if anyone here knows who these people are if they are famous for making trouble in thomastown area, since few reputable workshop around this area also says they seen these two people on the R34 drives around the area often and coming down asking for parts.
And maybe if you guys seen anyone here looking for front bumper replacement for R34 too, just remember they are little pu$$y criminal.
that makes my end of week work day
Back when Cube - was rollin wit Lorenzo in a Benzo
I was bangin wit a carpark of colleagues
Got the CCTV and license plate, got down to business; but sometimes
the front bar of this shit can turn thomastown against you
But you was a real nigga, I could sense it in you
I still remember the window of the grey R34 you went through
  • Like 4
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
