Alvin, I have seen a lot of people eat scotch fillets bleu. The best part is the people that order bleu always have to make a big deal about it and ensure everyone knows.
Then when they get their meal and realise just how bad a bleu scotch is, there is no way they will ask for it to be cooked more. And they are very aware of the whole kitchen laughing at them
lol need to rephrase then.
see people order and enjoy scotch fillets bleu.
hey Aayron, who did you hire your jetski from?
what sort of price?
an no Moh I don;t want to buy one, just rent for a bit..
The adrenaline place on the island.
Solo:FJ$538
Tandem:FJ$575 (that is FJD287.50 p/person)
Go quard biking though. Cheap and I would do it over and over again.. and ask them to take out the Baja..
http://www.fiji.travel/activity/go-trek-quad-tours
Personally the best thing I did there..
i'm sure everything is a defectable offence man. probably should just go commit some real crimes, maybe deal drugs or something. they dont get hassled as much apparently.
And they make good money rather than get money taken for no arbitrary reason...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
