ey blokes,
Where's the best spot in my cooling system for me to throw in the coolant temperature sensor for a gauge?
In the top hose (That's water coming OUT of the engine right?) using one of those adaptor blocks you can pick up from SCA?
Not sure if my Koyo Rad has a bung for a sensor... and if it does it'll be at the bottom so that'll be reading it at it's coldest point :/
Hot side of radiator, wherever most practical to hook-up on the hose
ey blokes,
Your anus.
with the clubby gone, and the micra finished for now, i needs another project.
if anyone knows of a gen2 subaru liberty wagon going for about 500 bucks, let me know.
Any purpose in mind?
Build up liberty
Sell impreza
Profit?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
