Lotta love for these MSI kunce
dat mag alloy body. MSI have been making video cards since forever, and they're the only ones other than apple that make half decent laptops with good screens, CPUs and GPU... you know... the shit you can't swap out. The GS60 also allows you to plug in two SSDs in RAID 0 for superfast OS... plus a mechanical HDD for storing all your pronz.
If you're hellbent on proving you're a sleeve tattoo rockin beefcake, you can get the GS70 with the 17" screen and bench that in the park to impress the ladies. The 15" is better bang for buck tho.
I can step down to 15 if need be, most shit gets watched through the TV anyway so screen size isn't vital.
The two you linked, one has better resolution, which is the cheaper one for some reason?
The other one is US price
pccasegear have good prices generally and decent MSI laptop selection:
http://www.pccasegear.com/index.php?main_page=index&cPath=1538_1539
sup mah niggas.
looking at purchasing my first property next year, so i come to pick your wiser and older brains.
lol jks.
wtb: 2 sets of GTR steel rear quarters, full set of sedan doors, no trims or glass required.
subtle*
the first one is the manufacturer site for the 3k model. It's got the highest resolution 15" screen after the macbook pro. It's like $2800+ or someshit here.
The second one is the one that's in your price range and the best choice IMHO. It's got HDMI out with audio passthrough so you can plug it into your TV and fap away.
I though all laptops these days would be able of being plugged into a TV... My current one was like $1200 and it came with it, 3-4 years ago.. Will see who has the second msi one in stock...
The cheap shitty dells and hps etc don't come with HDMI.
PCCG, but they're more expensive. umart will usually get shit within a few days of ordering it if it's a pre-order. It just means you can't rock up and expect it to be there in stock.
sup mah niggas.
lol jks.
subtle*
Saw that red one, was amzing
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
