if you want a cool story you should read the comments your mate posts after every status you post, referring ever so slightly to anything
he didn't make survive cull
Did a road trip to Moama, mate was in his Prelude. They have the non memory position diver seats like Skylines...I joked to him at the end of the trip that it'd be funny if I adjusted the seat (he was OCD about his seat's position and hated not being able to get it perfect after someone's fked with it), he took my joke very badly. Gathered Preludes aren't comfortable cruisers.
Oh well, enjoy Ric.
Bunch of slack-jawed faggots around here.
8 hours ain't shit, harden up fellas
Toe kills tyres. Camber just decides where it wears out the tyres first ay.
Centreline will be around $200. TruTrack around $180. Traction Tyres around $120
Cheers guys, didn't think it'll cost that much.
Those of ya'll not going to WTAC, come to Garage Cafe tonight... will be repping /evolinesaustralia... and picking my my drunk father from the city afterwards to give him a lift home from a work function. That'll be a fun drive home *le sigh*
i would come but im coaching some weird nation (seychelles or mauritious i cant rmemebr) in preparation for a world cup tournament in knox.
im telling you lot this in hope that someone knows anything about it. cos i dont. the owner just asked me to do it.
what? proper footy?
Free market will dictate what the event is worth...if people think it's worth it they'll go and the event will keep running...if not they'll shut up shop as the numbers dwindle over the years.
Which is pretty much what happened to autosalon. Does anyone remember autosalon? Yeah, I bet you do.
I first met Moh at an autosalon probably 4-5 years ago, he was by himself lol
Krysissyu still rocks one of those MASSIVE Autosalon Competitor stickers on his car lol
LOL!
1) Wear dick-tight short shorts
2) Have full sleve tats
3) Grow bush ranger beard
4) Pat your team mates asses at any and every opportunity
5) Do something retarded/illegal off field and receive preferential treatment
6) Repeat
  • Like 1
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
