VWL legal team... i need your help.
Just moved of house, agent is trying to take $200 out of my bond for cleaning (that was then cleaned by the owners). she has photo evidence of the items:
one is for mould on window sills of 3 rooms (barely visible)
section of uncleaned skirting boards.
inside edge of dishwasher not wiped clean
rim around 2 stove burners not clean.
I think its unreasonable because stove and washing machine were brand new 22 months ago (when we moved in) and that they expect it to be in the same condition... but it doesnt stop someone from renting it, therefore its not worthy to detract from bond. Especially since it affects my rental history majorly.
oh and i forgot to add that there were weeds down the side of the house i forgot to remove. all up would take half a day of work and some scrubbing for stovetop.
also note that house has been on the market for a few weeks now and has not been filled, had 2 inspections a week plus price drop and i dont think theres any takers.
I should have known
I should rock out with some 20" SSR professors, dat coin doe. Need 'fake' ones.
Edited by UNR33L
Half a days work... I'd be pretty happy they're only taking $200..
  • Like 4
the house has no grass or weeds or plants when we moved in...so backyard/side of house is bare. we were the first tenants.
i tried being reasonable and said $100 for the stuff i'd missed. if the owners did it in their own time, they dont earn cleaning rates. different if they got it professionally done and provided a receipt.
they ignored my offer for what I thought was reasonable and just said "please reply agreeing to the $200 so we can submit the return of your bond"
saw your car on VSKF's in 19....
looked TITS
will be bloody hard to get them in those sizes for $2k though
I'm almost tempted to try 20s again though.
Kind of like these TSW rims, around 2kish new I think.
c2bd321524596af01d30f6e4b63360c74f021b51
Edited by UNR33L
Sound like fussy owners over a bit of mould and some weeds.
Don't know enough about real estate but there's prolly $200 of profession work in it with weeding and mucking around with that shit. Was it like that when you moved in / in the property report? Have you done any extra (not required of tenant) maintenance for the place in your own time?
Next time give a kid $20 to do it for you
Oh and buy a Beko they're farkin great
Leigh, if you go 20's are grippy tyres available at reasonable prices? Or would moving to really low profile 20's going to cost you an extra $1k in tyres over the next 2 years due to 'rare tyre sizes'?
Why not spend half the day doing all that stuff rather than paying the $200?
I cant because the owners have already done it after she tells me about it (and after she took photos).
i know $200 is pretty small, but the mould and stove is petty shit. and I am tempted to throw in the towel, but it means that they can get away with an extensive list of little shit + one/two issues and guarantee a win regardless of going through the tribunal or not.
f**k em. its already wasted enough of my time. im FIFO bitch.
  • Like 1
The 20's suit that car well as the arches are HUUUUUGE, but those rims look aids... rears are OK but fronts suck the wang
Rodney Jane called, he wants his wheels back
lol BUUUUUUUUUUUURN
offer them $400
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
