Geelong bitter is where its at.
Was at asian beer cafe for some reason and drinking their goku beer or some shit. $8.50 jugs, never going to complain. That plus 2 long island iced teas for $14... Things got messy.
Fk you Nick. You are the worst influence on my bank account.
FYI Aldi liquor has it for $400 so DMs retail is a tad inflated for the offer, given they are usually the cheapest at retail price. Still a good price though.
Also Hamish...I've given my dad about 6-7 bottles of Johnny green over the years and drank a couple myself. Really hating myself for not just KEEPING THEM when people are offering them for this kind of money (not that they're necessarily getting sales at these prices).
http://www.oldrichmondcellars.com/spirits/blended-whiskey/johnnie-walker-green-15yr-1litre/
:| dat hipster green label
Porsche design put their name on just about anything... Phones, shoes, watches... Its probably an undergraduate program to keep people busy.
I can imagine people working at porsche for a few years and having nothing to do with cars.
I don't buy royal salute predominantly because I hate the bottles lol.
also there are better tasting whiskey's in that price range IMHO. Normal chivas is an epic daily when dan's have it for $38 doe
Birds I checked that safeway and no more green :'(
I used to smash it too :'(
eh.... some serious headaches from that shit back in the 90's when the public bar used to do dollar pots
Ditto for mid 2000s haha. I thought their 'Geelong Bitter' was just a euphemism for them mixing together almost empty kegs of any old shit though
Really? I love the bottles. Admittedly they look more like cognac or rum bottles, but I like those too. Certainly didn't buy it for the taste, I'm no scotch connoisseur, but I do like slightly collectable alcohols.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
