I'm not saying it can't be done it's just not preferred
And I would prefer not to do it, same as every other track day car, haven't seen one driver go out on a hot lap and time himself with a stopwatch in the events I have been too
It's cos they usually have someone doing the timing for them.
Either that or they don't care about times.
You land vaginas need to ride a bike at 250+ for some perspective
200 is maccas drive through, eat and change gears kind of shit
Have sent texts/snapchats @ 200+, not a single fuck was given that day
  • Like 1
love the price, target audience or what...
Pretty sure they're acknowledging the slow and steady Chinese takeover of Australia
The ultimate Chinese dilemma...do you pay $888 for it or bargain the price down...
  • Like 2
plus race chrono gives you splits, corner speeds and such so that you can look at your stats and work out how to go faster.
This is Mohsen's mate
His tyres will fall off the rims at turn 1
You probably gave a f**k to the person you were texting, but fair to say the rest of the f**ks remained untouched
  • Like 1
looooool.
Also make sure the brakes and brake pads are perfect, bring a spare set of pads just in case they decide to run low... because Sandown chews brakes badly... Slow cooldown laps of the track (and the carpark) and necessary as there's two x 200km/h stops per lap.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
