dont think i can afford to do the track day atm bruh.
dem feels. i has them.
im going as support wagon.
literally. a wagon full of tools.
still be quicker than most of the cars on the track lololololol.
come donw for pizza face painting and bouncy castle anyway.
isn't your car a relatively stock version of the same cars that are attending? (WRX's)
depends whats relative.
if you talking a fully built engine and 400kw, then yes.
if your talking everything you can do with out opening the engine, then no.
i has a bout 50kw more than stock atw, on 95 petrol.
soooooooooo, like every other car then?
  • Like 1
Yeah alot of the rex guys are quite quick.
Most of the regulars would be under 1min 30secs
So your probably not going to be as quick, unless you have ample track experience
That Simon Henman guy though...I heard his quick
thats what his missis said.
FYP brah
hey, should bring your public transport for a lap or two chum.
  • Like 2
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
