Well.... To actually have full grip they'd need to be at about 30psi hot... which would mean near 20psi cold / normal driving...
If you're running at 30psi cold... once they actually get up to temp then they'll be 42psi.
Note that "Hot" does not mean "I've done a quick burnout on them before a launch"
You're going to have an absolute ball on them if you dial them in properly on the track.
no he's not.... it's MOHSEN
you KNOW he only bought a PAIR and he has frikken ling longs on the fronts right?
Snowy Mountains 1000 over the weekend.
fastests car R32 GTR.
2nd fastest..
Jeep Gran Cheerokee
Damn
http://racing.natsoft.com.au/635860535/object_915454.82N/Result?8
That's fkin hilarious
What an awesome driver
At the same time, DECA has been won by FWD hatchbacks hasn't it?
got lang longs.
cheaper than ling longs.
nah, its got some bridgestones.
steers alright. does need ALOT of work aligning things etc now though. can feel everything wrong with it now, felt nothing with 225s and stretch lol
Lol if that's the case, dat under steer will be so bad
reverse everywhere
Oh my bad, it's a 1000 metre sprint, I thought it was a really short course like a wang
yeah long and straight, whould hate to try and get that puppy to turn!
(more so if you find pics the squat it has on launch makes me think still quitre soft suspension.
re DECA, I "think" a Type R integra won 2WD but not outright once.
that be it tho.
Moh you need to switch em around and have happy fun sliding times like me
What's the retail on AD08s these days anyway? inb4 more than you can afford pal
edit: http://www.tractiontyres.com.au/pdfs/a048_clearance_a4flyer-web.pdf
dem 19 inch feels :(
Edited by UNR33L
Thought about switching to 18's?
How small do they look on the titanic?
they look terrible, some guy on ford forums did it and wow lol.
standard they come out with 19s for a reason I guess
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
