but UK living expenses so spensive
thats why you live up north mate. 2 dollars a pint, houses are about 90k aud. jobs pay about 35k aud and everyone is nice, cos you have the same thing in common. you hate southerners.
*disclaimer
prices are relative to me leaving in 08/09.... may or may not be higher now.
*disclaimer
Sounds like my kind of living. What sort of land do you get for 90K?
Hnnnnnng that garage tho
http://www.realestate.com.au/property-apartment-vic-clayton-118326151
What you think Alex? might check it out.. I was looking more closer to the city but get shit all or something really old for your money the closer you get :\ Also this is across the road from Coles which is nice..
Edited by UNR33L
Looks ok man but suss out the body corp situation it can be high in those developments for bs things
bitch of a location IMO. level crossing causes traffic to bank up and no one in clayton can park or drive very well.
that, plus if they decide to get rid of the level crossing... thats traffic woes and construction for 6+ months
Also, theres 2 coles there. both stock the same shit and its not very diverse. i used to drive the extra 5mins to safeway on warrigal rd.
It's right across the road from Coles, that is the reason alone you should go 'shut up and take my money' mode.
And no, you won't see me covered in blood there.
wow 81sq including garage, I've stayed in hotel rooms bigger..
thus why I'm looking out of town.
I thought the 81sq was excluding the garage.. they usually do exclude the parking / storage in apartments I thought? if it's included then that's pretty bad and not worth looking at then lol.
Edited by UNR33L
Apart from a little traffic / possibly noise (would need to have a look) I kind of liked the location, near heaps of shops and the station would make it pretty easy to get into the city, walk across the road, grab a BBQ chicken dinner done.. :D
Inb4 walking across the busy road, get hit by car & ambo doesn't save me cos' shit wage
Edited by UNR33L
Clayton aye. Suburb across from me :thumbsup:
Also inb4 Korean girlfriend
from line under diagram seem to be included.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
